0 Members and 1 Guest are viewing this topic. Read 18325 times.
There are quite a few great options. A couple that I see recommended as tops:Eddie Current Balancing ActHeadamp GSX MK2 If you're willing to wait, Schiit has announced they're releasing a new flagship headphone amplifier (Ragnarok) later this year, earlier next. It should be a great performer for the price.
I am the happy owner of a Sennheiser Hd 800.I am using a Sound Devices HX3 as an amp.I am quite happy with the result,but could I get an even better sound using a more expensive amp,and if so which one?I listen mostly to well recorded audiophile music such as i.e. Carmen Gomes or Paul Berner from the Sound Liaison label Doug Macleod from the Reference Recordings labelBobo Stenson trio from the ECM label.If you go to one of the sites you can hear very good samples of their music.http://referencerecordings.com/http://www.soundliaison.com/http://www.ecmrecords.com/[/img]
I'm using the Bryston BHA-1 headphone amp with Cardas balanced Clear cables with my HD-800. The BHA-1 can also be used as a pre-amp with both balanced and single-ended outputs. It has both balanced and single-ended inputs and both types of female balanced outputs along with 1/4" and mini plug outputs.The BHA-1 will drive multiple headphones.Bryston are hand built in Canada and have a 20 year parts and labor warranty.Cost is $1,395 which I think is a steal.Bud
Been demoing the Burson Conductor Sl 9018 Dac. This is a sweet little headphone a Dac. Hard choice between the Bryston and Burson.
I can imagine that. They have been running a program where users write their feedback with certain headphone pairings. I'ts interesting the comparison vs the 1793 module.
What a lucky man. In that case i'll be interested to see how it works with all your gear. Hopefully in the future they include a LCD-X or MD?
