B-100 question
0 Members and 1 Guest are viewing this topic. Read 976 times.
gtaphile
B-100 question
« on: 10 Sep 2013, 11:18 pm »
James,
I am having difficulty getting the IR receiver to work with a repeater system.
It would help if I can confirm that the frequency range is in the 36 to 40 Khz range.
If that is correct then I need a high output flasher to overcome the slight recess of the IR in the Bryston.
Thanks Gary
  • The Demo is Everything!
    • http://www.bryston.com
Re: B-100 question
« Reply #1 on: 10 Sep 2013, 11:30 pm »
James,
If that is correct then I need a high moutput flasher to overcome the slight recess of the IR in the Bryston.
Thanks Gary
Hi Gary
Please email Mike - [email protected]
James
