No longer for Sale
0 Members and 1 Guest are viewing this topic. Read 1392 times.
nile49
No longer for Sale
« on: 10 Sep 2013, 03:48 am »
For Sale: Hypex NCore NC400 Dual Mono Amp in a custom case. The amp is in great condition except for some scratches on the rear panel from when I cut out the hole for the mute switch. Also the IEC I used doesn't fit perfectly in the case as I intentionally bought an IEC without a rocker switch for sonic reasons. I have been using this with my PS Audio Perfect Wave Dac MKII running directly into it with great results. I have resistor R41 removed at the moment which lowers the gain, thus making it a better match with my Dac's volume control. If you buy this amp and would like me to replace the SMD resistor to achieve the original gain do let me know and I will do this for you.
The amps were built with a Furutech IEC with no rocker switch. I have only a mute switch installed. I used Cardas XLR connectors and Eichmann Cable Pod binding posts. For the speaker wire I used Mundorf silver/gold wire. I have also installed Hi-Fi Tuning fuses. The front panel LED's are not connected.
Reason for the sale: I am moving to a Devialet.
Price includes shipping and paypal fees.
If you have any questions please ask!
« Last Edit: 24 Sep 2013, 05:16 pm by nile49 »
firedog
Your price is about what I would expect to pay for a new unit. Maybe slightly more (+$200). Am I missing something here?
nile49
Nope. It is true that you can get all the parts you see here for around $1975. Thought this might appeal to someone who is not interested in building their own unit, which would be an added expense and time to have someone else do as well. Also shipping/paypal will be around $100 dollars which I am covering.  So testing the waters at the moment!
Thanks! Warren
nile49
Bump. Listing will be pulled Tuesday Sept. 24th whether it sells or not!
