dampening sound from HVAC?
0 Members and 1 Guest are viewing this topic. Read 1869 times.
gregcss
« on: 9 Sep 2013, 12:29 am »
My HVAC system is in the living room behind a slotted door. There are no intakes here, they are else where. I'm looking at 1/2" 'high quality' neoprene foam roll from The Foam Factory (http://www.thefoamfactory.com/closedcellfoam/neoprene.html) to cover the door and possibly line the interior of the door with the same or other foam. I'll likely experiment with lining the interior of the door with cardboard and duct tape first. Any thoughts?
rajacat
  • Washington State
mcgsxr
Re: dampening sound from HVAC?
« Reply #2 on: 9 Sep 2013, 12:57 pm »
Any idea why the door is slotted?
If it is not a requirement, I imagine a Safe n Sound door and a good gasket all around the door would do wonders.   Under $100 at HD.  I use one at the top of the basement stairs with a good door sweep to help contains the HT sounds to the basement.
gregcss
« Reply #3 on: 9 Sep 2013, 04:44 pm »
Thanks for the idea. This is the door here:
Ethan Winer
  • Audio expert
« Reply #4 on: 9 Sep 2013, 05:27 pm »
If the noise is mostly low frequencies, foam will do nothing to help that. I agree with the advice to replace the door(s) and seal the edges well. That will also work better than MLV.
--Ethan
EdRo
« Reply #5 on: 5 Nov 2013, 03:24 pm »
     Hey guys. Just my 2 cents. I played bass in a metal band, in my basement. The ductwork sounded like it was ALIVE!!! After digging out all the loose change and toys it still vibrated like a wild thing, so I rolled contact cement over all the metal ductwork, and stuck on heavy carpet pad. It worked VERY well, and it was something that I could afford.   :thumb: Now, it wasn't very pretty, but a metal band doesn't care about "pretty"!
MtnHam
  • SoundLab and Fritz Speakers Dealer
« Reply #6 on: 5 Nov 2013, 07:42 pm »
Where does the combustion air come from?
mcgsxr
« Reply #7 on: 6 Nov 2013, 03:10 am »
I was assuming a high efficiency furnace (like mine) that has a feed directly from outside.
That negates the need for a "vent" of any kind between my finished space, and my utility space.
