Question on upgraded Stratos to kismet Hybrid
0 Members and 1 Guest are viewing this topic. Read 1778 times.
Caballero
« on: 8 Sep 2013, 07:38 am »
Hello all....Klaus has upgraded my Stratos to Kismet Hybrids, I have fully burnt them in now but now I have a question. It seems that I get some sonic differences from the left amp than the right that I have never heard before......I'm hearing small clicks and some small distortion during music play (my wife swears that the left side sounds louder than the right side). What is the best possible way to test to insure that both sides are equal so I don't have to ship them back to Klaus for testing (he's a busy man). I have checked all connections and the right amp sounds great its the left amp that seems to be having an issue unless the upgrade has uncovered some issues with my source (Sony Super Audio C.D player)
klaus@odyssey
    • http://www.odysseyaudio.com
Re: Question on upgraded Stratos to kismet Hybrid
« Reply #1 on: 8 Sep 2013, 08:52 am »
Aaaaaaaaaaaaaargh....   reverse the interconnects on the amps ONLY !!!!!  see if the clicks stay with the same speaker or if it goes to the other side....also, is one amp hotter than the other ???  Do you have them plugged in at same level outlets ????  Is this on all sources ????  Is this only with music playing ????
Check this and call me,
Klaus
Caballero
« Reply #2 on: 8 Sep 2013, 06:15 pm »
Klaus.....thank you for your reply, I will double check connections again and get back to you
Indiansprings
« Reply #3 on: 6 Oct 2013, 02:32 pm »
Why post these questions on a public forum? If you had an upgrade done to your amps and suspect an issue, contact the vendor in private. If the vendor cant or wont resolve it, then no problem asking publicly. Don't you think Klaus deserves that courtesy?
