FS Silver Modwright Transporter with EML 5U4G & Shuguang Black Treasures
0 Members and 1 Guest are viewing this topic. Read 1937 times.
mtruong34
Silver Logitech Transporter model with Transnav knob and has full Modwright Platinum mods. Comes with the best tube configuration available which is an EML rectifier (in use for about a year year on its proper voltage. So has many many years life), a pair of 'grade A' Shuguang Black Treasure 6sn7 signal tubes, and Bolder Cable 9 pin socket adapters for the 6SN7's.
There are two small 1/4 inch scratches on the back of the top and another smaller, lighter scratch on the side. Only viewable when up close and looking for them -- other wise, the unit looks great.
Asking $1850 + PP fees (no fees if gift option or money order) + shipping from Houston, TX as this particular unit comes with the best tubes that you can get for the MW.  I have 100% rating in ebay and audiogon under same name.
I'd be willing to entertain trades for a high end integrated such as MW KWI-200, Hegel H300, Pass INT-150, Pass INT-30A, NAD M2 or something else on that level with cash to offset.
« Last Edit: 26 Sep 2013, 12:09 pm by mtruong34 »
thomashek
hi,
What is the height of the unit with tubes installed ? Does the original opamp  audio output work as well ?
thanks
mtruong34
Hi,
Total height to the Shuguang tubes which are the highest point is about 8.5 inches.  I don't really know the answer to the second question.  I know there's a separate power switch in the back for the tube section.
-Mike
mtruong34
