MC 275 tube amp to drive headphones
0 Members and 1 Guest are viewing this topic. Read 1412 times.
spotlightaudio
« on: 4 Sep 2013, 03:21 pm »
I remember reading that Les Paul used an older Mc tube amp to drive his headphones in his studio. Is there a simple ,safe way to do this?
Would be driving BD T-1 600 ohm 4 wire config.  Thanks! :scratch:
dBel84
Re: MC 275 tube amp to drive headphones
« Reply #1 on: 6 Sep 2013, 02:24 am »
ESP provides a simple attenuator for limiting current / voltage to the headphones.
http://sound.westhost.com/project100.htm
to make something like this
the other option is to use a transformer but I can't recall the manufacturer.
ALO used to stock something for an off the shelf solution, perhaps someone else knows of a commercial product.
The one thing to bear in mind is that some amps do not like a common ground - i would put the output transformers on the MC275 into this category - thus the headphones will need to be used with balanced cables so as to avoid the common ground of the TRS plug.
..dB
dB Cooper
« Reply #2 on: 8 Sep 2013, 01:20 pm »
Also, hopefully the resulting 120 ohm output impedance seen by the T-1's and damping factor of 5 won't be a problem.
I would recommend a purpose designed headphone amp with a low output impedance. You could probably build a DIY O2 for about the same coin. If you want a reasonably priced tube headphone amp, there's the Millett hybrid and the Torpedo, or the Bottlehead Crack.
spotlightaudio
« Reply #3 on: 11 Sep 2013, 05:42 pm »
Thanks everyone for the input. Anybody tried the BHA-1 with the Beyer T-1s ?
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #4 on: 17 Sep 2013, 06:26 pm »
Used it, but not with the T1's.
I've read a review somewhere and the guy was using the Bryston with the Beyers.
