ground loop and nasty hum fixed
0 Members and 1 Guest are viewing this topic. Read 1059 times.
skifasterslc
« on: 2 Sep 2013, 04:44 pm »
Most of us have been plagued with insidious electrical noise from time to time. It can drive you bonkers.  I moved into a new place about 10 months ago and just last week I noticed a hum from my speakers.  I've dealt with this before so I was pretty sure what the problem was.
I am no electrician, I am just sharing my experience here.  At the moment I do not have my cable tv integrated into my sound system, however cable shares the same circuits and power distribution (ps audio duets) as my other sources.  I was pretty sure the problem was coming from the cable coax.  I ve had the same issue in other systems and with sat tv as well.  I had this holland unit on hand and for some reason did not install it on the system when i moved in.  just plug it into you box where the coax comes in and your done.  hum gone, no affect in picture (i think it improves it).  all for around $14
I know there are other products which can deal with other causes of noise problems, I just wanted to say for my problem in my system, this was an effective and economical fix. Hope it helps someone out there!
Features:
Blocks 60 Hz Power up to 5,000 Volts
Reduces The Energy Level of Spikes
Eliminates Ground Loop Hum
Spike Protection Circuitry (CISP)
Specifications:
Frequency range: DC-2150 MHz
Insertion Loss: 1. 5 dB @ 1 GHz
http://cdn.opentip.com/Electronics/Holland-Electronics-Cisp-Cable-Isolation-Filter-p-2302838.html?gclid=CInUjbKPrbkCFY5cMgodxQsATg
« Last Edit: 2 Sep 2013, 06:21 pm by skifasterslc »
Re: ground loop and nasty hum fixed
« Reply #1 on: 5 Sep 2013, 05:46 am »
Man, I went to order one of these today....  they want almost $60.00 to ship  one up here to  Canada , they'll only ship  from  that  particular warehouse to Canada via FedEx, not sure  what is wrong with a  couple dollar USPS mailer   :scratch:
-jay
sleepysurf
  • Member of the Suncoast Audiophile Society
    • Suncoast Audiophile Society
« Reply #2 on: 5 Sep 2013, 06:40 pm »
I'm sure you can find one of those on Amazon.ca
