Pro Amp Options
0 Members and 1 Guest are viewing this topic. Read 916 times.
slowdive_1
Pro Amp Options
« on: 2 Sep 2013, 03:31 pm »
Just wondering about options on the pro versions of the amps.  I understand that the pro versions are essentially the same as the c-series except for the faceplate and input level trimmers.  Can the pro amps be ordered with blue leds?  Also, are the pro amps only available in black?  I seem to remember that the earlier SST amps had the same faceplate as the current pro versions, and they were available in either silver or black.
Kind regards,
Greg
  • The Demo is Everything!
    • http://www.bryston.com
Re: Pro Amp Options
« Reply #1 on: 2 Sep 2013, 03:46 pm »
Kind regards,
Greg
Hi Greg
The Pro amps only come in Black and rack mount faceplates with green LEDs
James
slowdive_1
Re: Pro Amp Options
« Reply #2 on: 2 Sep 2013, 03:52 pm »
Ok, thanks for the quick answer James!
spinner
Re: Pro Amp Options
« Reply #3 on: 2 Sep 2013, 05:55 pm »
 Do the pro versions have a bit less resolution than the "C" due to the "trimmers" in the signal path? :scratch:
Re: Pro Amp Options
« Reply #4 on: 2 Sep 2013, 06:23 pm »
It should not really affect the sound much as long as the gain controls are fully open - but as i have said many times "EVERYTHING MATTERS"
james
