Recommendations for surrounds in a VR-35/LCR-4 HT setup
0 Members and 1 Guest are viewing this topic. Read 1360 times.
mdconnelly
I've been an extremely happy VR-35 owner for awhile now and recently decided to integrate these into a new HT setup using an VSA LCR-4 center channel.  My question is is what to use for the 2 surrounds.  A few things to note:
-- relatively small 12' x 12' room (although there is a large archway behind the listening/viewing spot into another room.
-- the surrounds will likely need to be wall mounted - either on either side of the archway behind the listening spot or on the side walls.
Any suggestions that would match well to the VSA front/center speakers?   I'd like to keep the surrounds easy on the budget.
Any advice or suggestions (or tales of woe) from those with a similar VSA HT setup is greatly appreciated.
roscoeiii
Re: Recommendations for surrounds in a VR-35/LCR-4 HT setup
« Reply #1 on: 1 Sep 2013, 04:05 pm »
I have some trapezoidal VSA rear speakers that are wall mountable which I can't use in my current space. PM me for details if interested. They were part of a killer 7 channel VSA system that was bought in 1999. Right now I can only use the VR-4 Gen II speakers, which are my mains.
JackD201
« Reply #2 on: 2 Sep 2013, 03:51 am »
See if you can find a used pair of VSA TS-150s.
In an ideal world go for a pair of LCR-4s and mount 'em.  :icon_twisted:
