Why Centered tweeters VS offset tweeters
0 Members and 1 Guest are viewing this topic. Read 1492 times.
skalos
« on: 30 Aug 2013, 10:42 pm »
Hi Danny,
To piggy back on the TMM question...
I see many manufactures using tweeters that are not centered on the front baffle for, I believe, diffraction purposes.  Your designs all have tweeters that are centered on the front baffle.  Why did you make this decision?
Steven
Danny Richie
    • http://www.gr-research.com
Re: Why Centered tweeters VS offset tweeters
« Reply #1 on: 30 Aug 2013, 10:51 pm »
Hi Danny,
Steven
Yeah it can become very necessary to offset the tweeter as baffle size starts getting larger. On a very small baffle it is not much of an issue. It also can depend a little bit on the shape of the tweeter face plate and if it is a shallow wave guide or not. This will vary the surface reflections.
My measurements have shown that on a small baffle it really doesn't change the response much in the on axis.
However, it can cause the horizontal off axis to look a little differently from left to right because moving left or right changes the time delay between the drivers and causes a phase shift. This can be especially bad of the offset is vary far or if the crossover point is vary high. Either of those things will cause a significant phase shift. Often I see the phase shifts in the horizontal plane to be much more of a signal imbalance than the surface reflections.
So I am not a big fan for most applications.
