NOH with Digital amps?
0 Members and 1 Guest are viewing this topic. Read 2982 times.
GordonJ
« on: 26 Jul 2004, 02:20 pm »
Wondered if anyone had any experience of using a Noh in a system with digital amplification.  I've heard very good things about Spectron and Bel Canto amps for example, but its really hard getting to hear them over here in the the UK.  Any thoughts about whether this is worth pursuing?
JoshK
« Reply #1 on: 26 Jul 2004, 04:46 pm »
I have played my Spectron with a Bent pre (similar to the now NOH preamp) and it worked out great!  Zybar uses the Noh pre with his Rowland digital amps.  Nothing to say that it won't work out great.
zybar
« Reply #2 on: 26 Jul 2004, 05:10 pm »
The BENT NOH works great with the Rowland 201's.
It also worked well with the H2O and AR digital amps.
George
J North
H20 v 201's
« Reply #3 on: 26 Jul 2004, 05:40 pm »
George,
Have you been able to compare the H20 to the 201's?
I have the Bent and am wondering about that.
michaelab
    • http://www.zerogain.com/forum
« Reply #4 on: 22 Sep 2004, 12:49 pm »
Sorry, haven't been here for a while.  Just to say that I use my NOH with a DIY digital amp I built using the ZAPPulse 2.2SE modules from LC Audio.
See here
The results are excellent.
Michael.
GordonJ
« Reply #5 on: 30 Sep 2004, 03:54 pm »
Fascinating thread, Michael, thanks.  Great to be able to follow you through the process.  Now I'm tempted to embark on a similar project...  Soldering iron probably a bit rusty but...  Will certainly check out the LC Audio site in more detail.
Cheers
Gordon
Brad
« Reply #6 on: 30 Sep 2004, 04:45 pm »
Hey Gordon, sorry to go off topic, but love your avatar
Cheers 8)
GordonJ
« Reply #7 on: 4 Oct 2004, 09:53 am »
Quote from: Brad
Cheers 8)
Why thank you!  It's a Llama I met in the Old Town Square in Prague last Christmas.  Not entirely sure what it was doing there...
Cheers
Gordon
