Suggest a preamp
0 Members and 1 Guest are viewing this topic. Read 1205 times.
this_is_vv
Suggest a preamp
« on: 28 Aug 2013, 04:22 pm »
Budget around $1500...
Current setup for left and right channel Pc and Receiver connected to DEQX
PC ->                   DEQX   -> 3 way active NCore based AMplifier -> 3 way speaker
Receiver  -------------|
now my DEQX is full(it has only one analog input used by receiver and 1 Spdif input used by PC) and i really not so much like the inbuilt DAC in it. My option are buy something like Mytek DAC and use  the analog input of that from my reciever  and  then use the output from Mytek to DEQX.
Also i just got into the GEEK DSD DAC from kickstarter which will deliever in Jan.  And i am moving so i wont have my music system till Nov end so i can wait for that.
SO i thought if i can get the GEEK why dont i get some Nice Preamp which will take all my input and can be used if in future i want to add some more ( i am thiking to add a vintage receiver for FM and a Vinyl collection ) and if it can have Phono input that would help a lot.
Again thought i throw it out here and know what all i should look for....
V
richidoo
Re: Suggest a preamp
« Reply #1 on: 28 Aug 2013, 06:22 pm »
Add a preamp if you want to easily switch between more analog sources, but other than that, DEQX is already a preamp with remote volume control, so you should try to fix whatever problem you have within the DEQX rather than paint over with tubes, if that's what you're thinking. You could also just add a simple analog input switchbox before the DEQX. You could make it yourself, or buy from finished unit from Goldpoint.
If you are inserting a preamp to fix the sound of the DEQX DACs then I think you are better asking DEQX tech support to help your fix it, or even hire them to fix it for you. I have heard quite a few DEQX based systems and they are consistently awesome tone quality when setup up correctly. I have never heard any problem with the output DACs, even on older versions playing on RAAL 5" tweeter. But the setup of those positive experiences has always been done either by experienced DEQX user Rick Craig or by DEQX tech support themselves. When it is setup by inexperienced users the sound is always compromised.
If you are just looking for transparent signal switching and volume control, I don't think you can beat the new Bent/Slagle preamp. If you want to add some phat lovin tone, look for 6SN7, like DeHavilland Ultraverve. These both are universally loved and good value, with good resale.
Have fun V! and good luck with the move!
Rich
this_is_vv
« Reply #2 on: 28 Aug 2013, 06:49 pm »
Rich
Thanks Rich,
Your DEQX point may well be very valid. I am trying to reach Rick on that.
Though i do need another input for as i am thinking to add a receiver and a Vinyl down the line and DEQX is totally out of inputs right now....
V
