0 Members and 1 Guest are viewing this topic. Read 10015 times.
How about these? http://www.safeandsoundhq.com/polk-audio-lsi-m705-floorstanding-speaker-(each).html
Are there. in fact, any real advantages (or disadvantages) of an oval over a circular shape?
In a circular driver, every point on the circumference of a circular driver is equidistant from the voice coil. So the cone resonances/breakup will be the same anywhere on the driver and strongest at a particular frequency. In an oval driver, both the distance to the edge of the cone and (as a result) the cone profile are different at different points on the driver and therefore the resonances and breakup artifacts should be more "spread out".
I should probably have just put on some music rather than sitting around thinking about technical b***s***.... I think too much
Aren't you listening to music while writing on the internet and thinking of all this stuff?
