Introducing the Remote Control Speaker Switch
0 Members and 1 Guest are viewing this topic. Read 1448 times.
LonnieBedell
« on: 25 Aug 2013, 04:59 pm »
The Remote Control Speaker Switch from Lonnie Bedell Electronics switches between 2 sets of speakers by remote control, allowing listeners to stay in the "sweet spot" of the room during A/B Comparisons. It uses a heavy duty relay, 14 gauge wiring, and spring speaker terminals. Binding posts can be ordered as an option. The LED on front glows green for Set A, and Red for Set B. The remote control is key fob sized, operates at 433mhz wireless band with approx 150ft range and is coded to reduce interference.  www.lonniebedell.com
jtwrace
    • TIPP YouTube Channel
Re: Introducing the Remote Control Speaker Switch
« Reply #1 on: 25 Aug 2013, 05:14 pm »
$95   :o
HAL
« Reply #2 on: 25 Aug 2013, 05:20 pm »
Will the binding post version also work with spade lug termination?
Are the output connections make before break to protect tube amp outputs from unloaded condition?
