0 Members and 1 Guest are viewing this topic. Read 8738 times.
Hello! I started bent audio to explore new ideas in audio and it has been some time since I did much exploring! ...
Hello!I have been really struggling to find time to keep up these past months and I am going to suspend deliveries of the NOH pre-amps until I get to a point I can build them and keep up with other things. I started bent audio to explore new ideas in audio and it has been some time since I did much exploring! This does not affect any of the pre-amps (or kits) I have orders pending for. All present orders will be looked after as you expect. I have just edited my web page to show the following no ...
John,I hope you figure out a way to get back to producing the NOH preamp. I have owned many preamps (costing anywhere from $500 to $4500 and being tubes, ss, or passive) and this is the "best" sounding to my ears. It is clean, dynamic, and just gets the heck out of the way.I am extremely pleased with this purchase and would heartily recommend it to others if production kicks back up again.Best of luck John.George
TKP,Would something like the Ultimate Attenuator work for you?http://www.tweakaudio.com/Fixed%20Volume%20Ultimate%20Attenuators.html
Hello!Thanks for the kind words you guys and good to hear from you TKP! I have had S&B make versions with taps lower down in level for folks with more efficient systems. We usually start at about -60 then keep the step sizes lower down load and go with large steps at the top of the volume - since in a system like that the upper settings would never likely be used. This puts the standard 2db steps in the range they are normally listenning. I can't see getting a LOT more taps in there but we could maybe s ...
