0 Members and 1 Guest are viewing this topic. Read 5037 times.
Google "VPI pop" and see all the talk about this. I always had it on my Classic 1.
Actually if you turned your phonostage to 'mute' when you turn on or turn off the player, wouldn't that be a way to fix the problem as well? I guess that depends on if you have a 'mute' button on your phonostage...
I believe that is referred to as a 'work-around'
Will this fix the HUGE pop I get through the system when I turn on the motor of my HW-17 record cleaner?Russ
