0 Members and 1 Guest are viewing this topic. Read 5307 times.
Hi, your description is a little hard to follow. This sounds like a microphone buzzing?This ground wire from your table to JC3 - is this the tonearm ground or a separate ground ? How many in total?Any new devices plugged in just before this started happening? neo
What cartridge are you using? Have you moved any pieces of equipment lately (power transformers can induce hum into phono circuits). Have you added any electronics to the system recently, even a wall wart can cause problems if too close to the arm/cart.Wayner
Because the system was running fine awhile ago and now there is a problem, makes me think that there is some kind of a contact problem, maybe even at the cartridge terminals. I know here, where it gets humid, then dry in just a couple of days, raises hell with the connectors. Perhaps simply unplugging the tonearm connectors and re-plugging them in will help, or better if you have some De-oxit 5 spray (don't spray on the cart, but in a small bowl or the cap of the De-oxit and then brush it on with a small (paint) brush.I'd also check the outer sleeve of the RCAs, for proper contact, and perhaps spray them too.It could also be the connector on the Scout, going from the tonearm to the little J-box. I'd unplug/replug that too. So that is at least 4 places for the signal to go to hell.It certainly is looking like a small, mechanical contact problem.
It pretty much has to be RFI. Wayner's suggestion is a good one, check your all of your connections. There is also another possibility, a new source of RFI has come online somewhere near you. A large increase in the amount radio frequencies bathing your neighborhood could be the straw the broke the camel's back. The give away to the RFI problem is the increase in the noise levels when you touch the tonearm, also the reduction in noise when you went to a better shielded cable. Your body is acting as an additional antenna and increasing the signal strength injected into the phono-stage when you are touching the tonearm. I suffered a similar problem when the selector switch in my preamp became intermittent and noisy. A thorough cleaning and then treatment with CAIG ProGold restored blessed silence and freedom from RFI. Scotty
