VPI-gimbaled arms ?
0 Members and 1 Guest are viewing this topic. Read 4849 times.
Minn Mark
VPI-gimbaled arms ?
« on: 21 Aug 2013, 12:26 pm »
So...
Anybody have the dish on VPI moving to gimbaled arms? The Traveler TT has a gimbaled arm; now I see the Classic series has updates, including what looks loke a motor repositioning, and the gimbaled arm.  I have a Classic I with the 10.5 unipivot, which with a Sumiko Blackbird, IMHO is a grest sounding table. So....why the switch to gimbaled arms at VPI?
PS- looking forward to a review of the 3D printed unipivot arm ($$) released of late as well.
Happy to read your responses.
Mark
neobop
  • BIRD LIVES
Re: VPI-gimbaled arms ?
« Reply #1 on: 21 Aug 2013, 03:03 pm »
I doubt that - moving to gimbaled arms that is.   The 3D arm is now for sale for $3K to $5K depending on length.  The only gimbal arm I see in their line up is on the Traveler.
Did you see a prototype or a modified table?  Maybe they're coming out with a less expensive Classic with a Traveler arm?
Repositioning the pulley would be logical, but I don't know how much it would effect performance.  The theory is that performance would be enhanced by having the pulley directly opposite the arm pivot on a straight line intersecting the spindle.  The way it looks now, that would mean putting it further back.  It also looks like the platter would have to be moved as well.  I'm looking at this from beauty shots so I'm not exactly sure, but that's how it looks.
neo
Devil Doc
  • On the road to Perdition
« Reply #2 on: 21 Aug 2013, 03:06 pm »
A more sophisticated gimbaled arm is now offered on the Classic 2.http://www.analogplanet.com/content/vpi-debuts-new-4000-classic-companion-turntable-complete-tone-arm-and-custom-grado-cartridge
Music Direct, for one, has them for sale for about four grand.
Doc
neobop
  • BIRD LIVES
« Reply #3 on: 21 Aug 2013, 03:58 pm »
Couldn't find it at Music Direct, not today.  Looked at all the VPI, maybe I missed it or they sold out.
With this new version of the gimbal arm and bundled with a Grado Sonota,  it's essentially the same price as the other version.  Some people have trouble using unipivots or don't like them.  VPI certainly has an extensive lineup.  This looks like a move to cover all bases rather than a shift to conventional arms, but you never know.  Maybe they'll come out with a 3D version.
neo
Devil Doc
« Reply #4 on: 21 Aug 2013, 05:03 pm »
Oops, try Acoustic Sounds.
Doc
roscoeiii
« Reply #5 on: 21 Aug 2013, 09:19 pm »
On VPI's Facebook page they said they'd add something on unipivot vs gimballed to their webpage. They mentioned Grado MI carts as working better with gimballed designs.
YoungDave
« Reply #6 on: 21 Aug 2013, 11:04 pm »
I have the 3d printed arm in the 12.7 version on my HR-X.  Have had it for about a month but am not yet ready to write a critique.  Have listened to it a lot and like the sound.
roscoeiii
« Reply #7 on: 21 Aug 2013, 11:05 pm »
Anxiously awaiting your review.
What cart are you using?
Minn Mark
« Reply #8 on: 22 Aug 2013, 06:01 pm »
+1
Looking forward to your critique on the 3D arm.
Mark
nnck
  • Music Collector, Audiophile, in that order :)
« Reply #9 on: 3 Nov 2013, 03:49 pm »
By now people may have seen that VPI has indeed added a gimbaled arm design to at least one model of it's Classic series (Classic Companion: http://vpiindustries.com/table-companion.htm). Now that there seems to be some choice in the Classic series of either Unipivot vs Gimbaled arms, I'm interested in learning more.
Can anyone explain what a gimbaled arm is? How it works? How is it different from a unipivot (I have a Scout so I am familiar with these)?
Pros/Cons of these arm designs anyone?
« Last Edit: 4 Nov 2013, 01:46 am by nnck »
Ericus Rex
« Reply #10 on: 3 Nov 2013, 11:05 pm »
Gimbal-ing is where there are two different sets of bearings for the different ranges of motion.  There is the bearing that controls the rotation of the arm and there is another bearing (usually a pair) that controls the up-down range of motion (gun turrets on ships are usually gimbaled, if that visual helps).  Unipivots have a single 'bearing' point that allows all ranges of motion, unfortunately including the wobble which isn't present in gimbaled arms.  Unis have less friction by definition.  As for the sound differences, I'll let someone with more uni experience than me take on that one.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #11 on: 4 Nov 2013, 01:40 am »
Is the ability to change the azimuth available on a VPI gimbaled arm or on the Traveler? Can azimuth be corrected on a unipivot VPI arm?
Best,
Anand.
Grbluen
« Reply #12 on: 4 Nov 2013, 02:07 am »
Yes, azimuth can be corrected on the VPI unipivots.
