SOLD/// Audio Outlet strip/ power dist. / Furutech type outlets Copper & Gold
0 Members and 1 Guest are viewing this topic. Read 1169 times.
undertow
SOLD
Custom made High End Audio Outlets / Power distributor / Furutech type outlets Copper & Gold
These are pure power distribution blocks, No filtering, No Fuse, No power switch, No current limiting surge devices, Direct to wall.
Might have some very minor flaws in the gloss black powder coating during the process of finishes. Might have a scuff or two on them as well.
You will have a hard time seeing any real flaws! They look and perform top notch.
The perfect solution for high end systems, mono Block amplifiers, or simply a no compromise power distribution need.
Specifications :
-180 degree directional mounting (See photos), very compact and cool design.  Can even stand up behind rack unit flat against wall or on shelf.
-10 gauge Cryogenically treated copper buss bars only 6” of length for maximum current delivery. Excellent for placing between Mono block amplifiers or any other gear on a shelf.
- 2 (clear duplex) outlets sourced from a company like Furutech, or Oyaide overseas, they are 100% copper, with Gold plating.
- 1 high end 15 amp IEC power cord input, you supply your own power cord none are included.
- Box is fully shielded and weighted for best RFI/EMI performance.
- Box is fully powder coated.
- Box has rubber feet on 3 sides so you can stand up, or lay down in any direction your cables run for 100% flexibility see photos!
- Size 4.75”w x 7.75”d x 3.05” h
Weight = 4lbs
I have a couple of these extra from putting in systems and they are just not needed right now so grab them for less than these kind of 99.00 outlets for one cost!
I forget the actual manufacture of outlets I had put in these, but they are basically identical to the Furutech clear gold/copper types. There are 2 outlets in each which can run most systems with 4 outlets.
Again a couple are available and I will even include Priority mail shipping with the price and paypal fee's....
$ 79.00 EACH! Basically Zero risk, and these replaced 2 - 1200.00 dollar units in my system the Isotek, and a an Acoustic Revive with better results of just pure power not adding color to the cables being used.
Make sure to reply here to grab one, if you need more than one let me know.
« Last Edit: 4 Sep 2013, 02:30 pm by undertow »
starkiller
Hmm, how much for shipping to 98327??
undertow
Hello as stated I will ship Priority mail in the price.
Let me know...
starkiller
Oops, sigh, missed that part in your listing :duh:  Give me a few hours to debate this with my checkbook...cash talks i assume?
undertow
Well or paypal!
I have a couple available so grab em' while you can.
[email protected]
aln
Received outlet!
« Reply #5 on: 27 Aug 2013, 11:51 am »
A wonderful package-looks great-sounds great!  Just received it yesterday and I put it in my system where it is powering my phono preamp and turntable.  An excellent buy.  It makes me think I might need another!
Al
undertow
Great... Let me know.
If the demand is more I will make more. It is custom, but the outlets might change if I do more.
I do have another one like this so let me know before it sells.
