Toslink to coax
0 Members and 1 Guest are viewing this topic. Read 1749 times.
martyo
Toslink to coax
« on: 20 Aug 2013, 04:49 pm »
Is the Inday Model: DA4X-R digital converter still THE unit if I have a Toslink input going to the Ultra DAC? Thanks.
Re: Toslink to coax
« Reply #1 on: 20 Aug 2013, 05:20 pm »
Good question marty, will be interested to hear Frank's input. I'm still using 2 of them, one here in the office, one out in the main system.  :wave:
JerryM
  • Where's The Bar?
Re: Toslink to coax
« Reply #2 on: 20 Aug 2013, 05:35 pm »
A mighty fine Toslink to coax converter most likely lies within each AVA 'EC' rated DAC. Maybe another opportunity for the small Humdinger box?  :scratch:
Wayner
Re: Toslink to coax
« Reply #3 on: 20 Aug 2013, 06:40 pm »
I'm using it with fine results.
Wayner
martyo
Re: Toslink to coax
« Reply #4 on: 20 Aug 2013, 06:45 pm »
Hi JD, I forgot that. Have a 2nd source for the DAC now (new TV) and its a Toslink.
Thanks, I'm just going to order one.  8)
martyo
Re: Toslink to coax
« Reply #5 on: 20 Aug 2013, 06:46 pm »
Wayner
Thanks Wayne.
dlparker
  • Dave Parker - KC, MO
Re: Toslink to coax
« Reply #6 on: 20 Aug 2013, 06:53 pm »
Wayner
Same hear (fortunately the I can't 'hear' the groans over the 'net!).
Re: Toslink to coax
« Reply #7 on: 21 Aug 2013, 01:51 pm »
Don't forget you can order them with a Blue or Green light now  :o   :thumb:
martyo
Re: Toslink to coax
« Reply #8 on: 21 Aug 2013, 02:00 pm »
Yep. Thanks. I ordered one yesterday with the blue, and the 2 additional cables I'll need from BJC.
I can "see" the one in your office now but can't remember the one in the big set.
