BDA-2 and BHA-1 have a different finish on the top and sides - why?
0 Members and 1 Guest are viewing this topic. Read 1486 times.
R. Daneel
Hi folks!
A few days ago I purchased the BDA-2 D/A converter. I am very happy with the audio quality and build quality. However, I do have one question regarding the finish on the BDA-2. About seven months ago I purchased the BHA-1 headphone amplifier and, like with the BDA-2, I am very happy with it. What is puzzling me is the difference in the finish between the BDA-2 and BHA-1. There are no differences on the front panel but the top and side panels are obviously different. While the BHA-1 finish is smooth, the BDA-2 is really not and seems a lot more rough to me. I don't know why this is the case but the bottom panels on both machines appear to be the same and as smooth as the rest of the panels on the BHA-1.
Would someone please comment on this?
Cheers!
Antun
  • The Demo is Everything!
    • http://www.bryston.com
Hi folks!
Cheers!
Antun
Hi
There will be some variation in finish and paints used over time
James
R. Daneel
Hi
James
Hi!
Thank you for your reply! I suspected that you did some changes on that department. It is not a problem at all.
I never stack my components together so there is no chance any harm will ever come to them. Still, your build quality gives me plenty confidence.
Cheers!
Antun
