Record cleaning machine causes static
0 Members and 1 Guest are viewing this topic. Read 1225 times.
« on: 18 Aug 2013, 02:25 am »
I got a VPI record cleaning machine and it started to cause static. I was told that this is normal. Is there anything that can be done?
S Clark
Re: Record cleaning machine causes static
« Reply #1 on: 18 Aug 2013, 02:30 am »
These shouldn't cause static?????  The moisture should allow for charge build up to drain.  I guess you could mist the area with water before cleaning, raising the humidity.  Perhaps use more cleaning solution.   :dunno:
Scott
krustykat
« Reply #2 on: 18 Aug 2013, 03:29 am »
I had the same problem with my VPI.  I'd take the record off, and then snap, crackle pop and all sorts of dust would get re-attracted to the record.  I was able to solve the problem by using a Milty Zerostat on the record cleaner.  Using the Milty Zerostat is now a normal part of my record cleaning process.  I zap each side on the machine after I clean them.  Never a static problem since I started doing this.
SteveFord
« Reply #3 on: 18 Aug 2013, 12:24 pm »
Either the Milty of hit it with a damp Discwasher or Parastat brush.
Mr. Don
« Reply #4 on: 18 Aug 2013, 04:12 pm »
Yes, static will occur due to the friction of the wand on the record as well as the friction of the air rushing through the slot against the secord surface. I use a Zerostat to neutralize the charge before removing the record.
andyr
« Reply #5 on: 20 Aug 2013, 03:40 am »
I suggest you need to get yourself a new RCM.  I've been using a manual Nitty Gritty for over 20 years and have no static after cleaning.
Andy
