searched this circle for info on a carver cm-1090 integrated. nothing came up
0 Members and 1 Guest are viewing this topic. Read 4331 times.
terry parr
anyone have any first-hand and more importantly, first-ear experience with this amp?  i'm in touch with someone local (within 50 miles) to schedule an audition.  noticed that this particular amp came up for sale just this past week on craigslist.  just can't come by a lot of informed opinion on this piece, either here or anywhere else.
to me, it's a very attractive-looking piece of kit.  with the vu-level meters it gives this amp a retro look (which is right down my alley, some may not like the look, but i do).
bottom line, though is how it sounds.  i'm not planning on buying it only to look at it.  although, from a design perspective you can tell that some thought was put into how the piece would look from an aesthetic viewpoint.  it's an impressive-looking piece to me.
question for anyone reading is this:  this piece is obviously getting a bit long-in-the-tooth now, and does anyone have any info on the availability of replacement parts?
or any suggestions for further reading i could do to get more info on it?
anything that anybody has on this would be appreciated.  thanks, guys.
SteveFord
I have no direct experience but I'm sure one of the guys here
http://www.thecarversite.com/yetanotherforum/default.aspx?g=forum
could help you out if no one here has one.
From doing a quick search over at thecarversite one fellow said the preamp section was probably the weak link in it and another guy had to source parts from China when his needed some work.
Hope this helps some.
terry parr
thanks, steve.  appreciate your post.
yeah, that's some of what i was afraid of.
although i was excited when i saw this piece for sale, i've still been kinda "biting my lip" about it, as i'm mulling it over and looking for more info on it.
i still have some research to do.  i appreciate the link.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
The 1090 it's basically a TFM-15 with preamp, it may need to be recapped to bring it back to life again.
I saw one listing on ebay and it was sold pretty fast.
terry parr
 i went ahead and picked up the one i was looking at.  labor day mon. will make 3 weeks that i've had it.  after i went and looked at it, and listened to some familiar music that i took with me, i decided to get it.
cosmetically, it's perfect.  he took very good care of it.  you can tell.  of course most people will take good care of a nice piece like this.
it does need some bench time, however.  luckily, i've already got somebody in mind (who has worked on other carver gear before).  so now i'm looking at deciding on replacement caps, and a couple of other odds and ends.
i think the main reason the guy who sold it let it go was that he didn't know who might be able to fix it.  he probably didn't know a repair tech, or somebody still doing electronics repair.   so, he wanted to get what he could out of it, while he could.
this piece does have a couple of areas that need attention.  the balance control for the left side is fine, but on the right side you are limited by how much signal you can hear before the signal begins to distort.   and the watt meters show this.  the right meter only indicates about half of what the left channel is indicating.   still, though you can get a satisfactory balance between left and right when listening through headphones, but where this discrepancy really shows is when you connect speakers.  then it seems, you're only able to hear the left channel only, with very little coming out of the right channel.
one other thing is the "cd direct" switch.  when you try to engage this, then all signal is lost.  so, you're unable to hear how this piece sounds perfectly flat, without the tone controls being engaged.
right now, i have the cdp plugged into the "video 2/aux" input on the amp.
when i was talking to the guy who was selling it about these flaws he said that if i could find somebody qualified to bring the amp back up to spec, then i would probably have a fine piece that i would get a lot of enjoyment out of.   so, now comes phase two:  getting these minor flaws addressed, and hopefully everything will go well during the repair and restoration.
during the audition a few weeks ago, you could tell that this is a fine-sounding amplifier.  refined sounding.  a bit neutral, yes.  a bit "recessed-sounding", (dare i say, "a bit tube-like"), but with solid-state impact (but not too much impact, if you know what i mean).  the bass is what i would consider "controlled" and "focused".  i've always hated the term "tight bass", because usually when someone says the bass is "very tight", that usually means very little if any bass impact.  but this amp has impactful bass (if that's how the recording was mixed, then you'll hear it through this amp).  but, the bass isn't "bloated", or over-stated.  to me, the bass presentation is getting very close to "just right."
no piece of equipment is perfect (not through all the frequency spectrum, or across different genres of music), but considering how this amp sounds from the low freq.'s to the mid-range presentation, and how it delivers the highs, i'm very impressed with how musical this amp sounds.  i like the way it was engineered to sound this way.
if everything works out once it goes to the shop, then it'll be my "go to" amp.  all things considered, i thought it was worth taking a chance on.
but, like they say:  "you pays your money/you takes your chances."   here's hoping.  but, we'll see.
Noseyears
  • SS-Audio
You made the right choice man, it's hard to find a bad review about this model.
All things should go as expected.
terry parr
thanks, noseyears.   i'm hoping...
this carver ranks #1 in overall sound quality compared to the other amps i've auditioned in the past year-and-a-half.  (although the anthem 225 is no slouch as far as sounding refined and musical.  i just remember writing in my notes at the time that the anthem sounded a bit "too polite" for my taste.  but, overall it's the amp that gets closest to the carver).  i noticed that with the anthem, even on tunes where the bass was pretty much foreward or pronounced, the anthem would "subdue" the bass presentation.  (for lack of a better way of describing it).  and on tunes where the bass line was placed a bit far back in the mix to begin with, then you were left with the impression that the amp was a bit bass-shy.
remember, though.  i listened to this amp only through headphones.  (which means i'm evaluating the pre-amp section only).  matching up the anthem with a complimentary set of good loudspeakers might would make me revise my impressions of that amp.
to steve ford:  thanks for the carver site link.  i'll be using it, since i have some homework to do on carver gear.
