NAD 1700 Preamp/Tuner (High Output rca jacks vs normal jacks)
0 Members and 1 Guest are viewing this topic. Read 2560 times.
man630
I recently picked up a NAD 1700 preamp and a Urei 6230 Pro Amp at a storage auction. My question concerns the high output rca jacks on the NAD.  Currently I'm using  the normal jacks  but I was wondering if the high output jacks would work better with Urei? The Urei manual states (max. input sensitivity +20db (7.75v. rms) The NAD manual states the high output jacks can be used with pro audio equip., can drive  load impedance's as low as 600 ohms and can deliver an undistorted signal up to 15 volts (+26db) to a high impedance (bridging) load. I think from this info the high output will be to high to use with Urei? Any schooling on this subject appreciated.
Randy
