Sansui TU-710 tuner in excellent condiiton (same as TU-717)
0 Members and 1 Guest are viewing this topic. Read 3103 times.
apt_one
Sansui TU-717 am/fm stereo tuner is in excellent condition, all lights, controls work exacly as they should. This tuner sounds great, offers alot of fexibility and really pulls in stations well. You will haveto search long and far to find one in better shape than this.
FM front-end with low-noise, dual-gate, mosfet RF-amp tuned via precision frequency-linear, wide-gap, 4-gang, variable capacitor.
Price is $239 plus shipping, add 3% if using paypal. USA shipping destinations only.
Information:
Low-distortion IF Section with linear-phase ceramic filters.
Wide-range ratio detector.
Low-distortion, phase-locked-loop, multiplex demodulator.
Wide/Narrow fm bandwidth selector.
FM noise-canceller.
FM muting.
Calibration tone.
Variable output.
FM Section Tuning Range 88~108 MHz 50 db Quieting Mono 12.5 dbf Stereo 34.0 dbf Sensitivity (IHF) Mono 9.8 dbf Stereo 19.0 dbf Signal To Noise Ratio Mono 81 db (at 65 dbf) Stereo 78 db (at 65 dbf) Frequency Response 30~15k Hz / +0.2 db, -1.0 db Total Harmonic Distortion Mono < 0.06 % at 100 Hz < 0.06% at 1k Hz < 0.08 % at 6k Hz Stereo < 0.10 % at 100 Hz < 0.07 % at 1k Hz < 0.10 % at 6k Hz Capture Ratio 1.0 db Alternate Channel Selectivity Wide 50 db at 400k Hz Narrow 80 db at 400k Hz Spurious Response Ratio 90 db at 98 MHz Image Response Ratio 86 db at 98 MHz Stereo Separation 45 db at 100 Hz 48 db at 1k Hz 38 db at 10k Hz Antenna Input Impedance 75Ω via coax F-connector
AM Section Tuning Range 540k~1600k Hz Sensitivity (Bar Antenna) 47 db/m (220 uV/m) Selectivity (+/-10kHz) 35 db at 1 MHz Signal To Noise Ratio 52 db Total Harmonic Distortion < 0.35% at 80 db/m
Miscellaneous Output Level 0~1V Mains Voltage 120V, 50/60Hz Power Consumption 20W Dimensions 17"W - 16.3"D - 6.6"H (19"W w/optional handles)
email me at [email protected]
Buyer to pay via money order or verified paypal (add 3%.)
iamjaymo
Re: Sansui TU-710 tuner in excellent condiiton (same as TU-717)
« Reply #1 on: 16 Aug 2013, 08:05 pm »
These really are fine tuners - had a couple in my day. Good luck!
Goosepond
  • Virna!
« Reply #2 on: 17 Aug 2013, 03:45 pm »
PM sent.
Gene
