0 Members and 1 Guest are viewing this topic. Read 3469 times.
That's about right for a 10 foot listening distance and your SPLs. Even if you listened at 87dB peak, you'd still only use 10 watts.
Wouldn't 87dB from a speaker with 87dB sensitivity only be 1 watt of power? What am I missing here?The general rule of thumb that I've heard is to plan for power transients 10x your average listening level. In your case it would appear that 20 watts is more than enough.
Sound volume diminishes with distance.Standard speakers (non line source) lose 3db in volume with each 1M of distance I believe, so he is losing about 9db by being 3M from his speakers.
Depends on the distance from the speakers. Close to the speakers you will be at 87dB, but as you move further away the spls will decrease.
Have you ever measured this in your rooms?
But the first meter is within the spec, right? 87dB 1 watt/1 meter, so we're only talking about 2 meters diminution, right? So that's 6dB and so since power must double for every 3dB of gain and since he's using less than 1 watt average we're talking under 4 watts at 3 meters. Is this about right?
