Audio/Video Gear and Systems
Owner's Circles
VMPS Speakers
RSorak
Need Grills for RM1 Speakers - VMPS Not Able Help!
0 Members and 1 Guest are viewing this topic. Read 1847 times.
DuDro
25 Jul 2004, 05:37 am »
My pair of RM1 speakers were damaged during a move. I need to replace the grills.
VMPS states that replacement grills are not available!!! This is hard to believe since the RM1 is a current model.
Please let me know if you have a spare grill for sale or know where I can obtain one.
Thank you for your time and help in advance!
Best Regards,
DuDro
[email protected]
rosconey
25 Jul 2004, 10:47 am »
give them a call anyway and find out from big b- he might throw you a bone if your nice
Bingenito
Grills
Reply #2 on:
25 Jul 2004, 02:38 pm »
I agree that you should be able to purchase any part for a current speaker.
Is the wood frame broken or just the cloth?
Grills are very easy to build using MDF or plywood frame, 3M spray glue and some grill cloth which you can buy from
www.partsexpress.com
or
www.madisound.com
Brian Cheney
grills
Reply #3 on:
25 Jul 2004, 03:10 pm »
Email me your name and address and we will send you a RM1 grill n/c.
I seem to remember dealing with this issue before. Current RM1's are from a different run and the fasteners may have to be moved or changed to velcro strips. That's not difficult.
DuDro
Reply to Big-B
Reply #4 on:
27 Jul 2004, 04:46 pm »
Brian,
Thank you for your help!!!
My email is
[email protected]
I will send you an email with my shipment details.
Owner's Circles
VMPS Speakers
RSorak
