0 Members and 1 Guest are viewing this topic. Read 3734 times.
I didn't give you enough info Don.....sorry....here's some more....The "active"* WD does have a power switch. I've never used it, and it does shut down (automatically) when it see the unit it's connected to shut down. If you'd like, I'll find out what it does when I hit the power button. Lemme know.The "passive"* WD portable drive: Does not have a power switch. It shuts down when the truck shuts off, since that's its source of power. In a conventional setting (like a home), I guess it would depend on whether the USB jack of your PC goes dead, or stays 'hot' after shut down. I don't know what it would do if it saw the unit it was connected to go to "sleep". I can find out, if you'd like. Not sure I've ever seen a 1TB 'passive' portable, but I've never looked, honestly. * I used the term active and passive like we would in the speaker world. Meaning self powered or relies on being powered. I hope that's understandable.
For my PVR, I need to use an external drive that does not shut down. I use a drive toaster, with a power switch. It runs 24/7.For my music server, I use an external Seagate with a power switch, but not a toaster. I am not sure if it ever shuts down or not, I have not spent the time staring at it!I considered a portable drive (one with no power switch, or outboard PS) but the cost kept me at bay.
