0 Members and 1 Guest are viewing this topic. Read 2463 times.
Wouldn't it most likely be the drivers causing it? I think it would be pretty hard to tell an A/B difference with/without bi-wiring and with/without cap upgrades (I'm not judging, I'm upgrading the caps in my SS8s as well). My guess would be the Accuton driver sounds much better than the SEAS Excel driver for handling vocals?Jon
You are probably correct. My issue is still that I live in Nyc, so space is an issue. I have some fairly sub-optimal placement issues. I use a Meridian 861 for room correction and have also used REW. Though admittedly, I have only scratched the surface of REW (do I really need to calibrate my mic?...) I also use all three channels for music, as that is one of Meridians little specialties. For action movies, it's not an issue, but for music, there is definitely a bit of a disconnect. It was probably silly to think there wouldn't be. I will reach out to Jim. I have him contemplating something else for me as well.
And since you brought up room correction...you may want to make sure that something bizarre isn't being applied to the center channel vs the L/R. Put it all on bypass, is it still terribly mismatched?
