Audio/Video Gear and Systems
Owner's Circles
Well Tempered Lab
/mp
WT Record player bolt size
0 Members and 1 Guest are viewing this topic. Read 1731 times.
Piperb
7 Aug 2013, 09:30 pm »
Hi
Wondered if anyone can help me
Does anybody know the size of the bolt that holds the arm pillar in place in the side of the WT record player and what thread type it is? I'm trying to find a replacement and spares are pretty thin on the ground now.
Many thanks!
Piperb
Re: WT Record player bolt size
8 Aug 2013, 12:19 pm »
Having done a bit of digging, this may also be called the 'set screw' but still cannot find a size or spec of what it actually should be
Piperb
Reply #2 on:
12 Aug 2013, 01:09 pm »
I'm guessing from the silence that nobody knows the answer to this so does anybody have an email address for Mike Pranka so I can ask the question directly to him?
Piperb
Reply #3 on:
15 Aug 2013, 11:38 am »
Well quite a few views but not a single reply, can anybody at least give me a pointer to contact either Mike or somewhere that may have the answer? It seems such a simple request
threadkiller
Reply #4 on:
15 Aug 2013, 05:34 pm »
Oh sorry, I don't look at every thread.
You can get a hold of Mike at Dynavector USA 's website..
The record player was the only older Firebaugh table I haven't owned..
SteveFord
Volunteer
Reply #5 on:
23 Aug 2013, 06:26 pm »
The one on my square motor is 10-32 x 1/2" and I suspect yours would take the same critter.
Owner's Circles
Well Tempered Lab
/mp
