headphone amps
0 Members and 1 Guest are viewing this topic. Read 2007 times.
parr3n1
headphone amps
« on: 5 Aug 2013, 09:05 pm »
Wondering what the difference is between a single ended OTL
and a set class A transformer coupled amp?? I am looking for a
tube amp for Senn. hd600's.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
Re: headphone amps
« Reply #1 on: 6 Aug 2013, 03:49 am »
Not much into tubes myself, but this is helpful.
dB Cooper
Re: headphone amps
« Reply #2 on: 6 Aug 2013, 11:48 am »
Bottlehead Crack has a following as an OTL amp.
Torpedo is transformer coupled at close to the same price.
Both available kit or assembled.
parr3n1
Re: headphone amps
« Reply #3 on: 6 Aug 2013, 01:01 pm »
Noseyears, thanks for finding that info. It was perfect.
Cooper, I actually looked at the Bottlehead and decided
that I did not want that build project. I am currently looking
at the Woo Audio wa3 and 6 and the little dot mkiv se.
hibuckhobby
  • On a search for audio nirvana
Re: headphone amps
« Reply #4 on: 6 Aug 2013, 01:27 pm »
What's your budget range?  There are some used Woo's and Bottleheads out there.
The Crack sounds better IMO on the HD600's, but the Woo is more versatile due
to the impedance switch and design so you can drive a wider variety of cans with it.
regards,
Hibuck....
R_burke
Re: headphone amps
« Reply #5 on: 6 Aug 2013, 01:43 pm »
I own a Woo WA-2 and like it a lot.  With it I have preamp and headphone amp together in one unit - save $ and space.  Although I like the Woo a lot, the unit I like even more is the Eddie Current Zana Deux SE, again a combo pre and headphone amp.  I'm just too cheap, it's $2,200.
Re: headphone amps
« Reply #6 on: 6 Aug 2013, 02:27 pm »
The short answer is the circuit is whole different and there is a output transformer.
OTL for 895 greens: http://www.decware.com/newsite/CSP2.html
dB Cooper
Re: headphone amps
« Reply #7 on: 6 Aug 2013, 05:06 pm »
Don't remember which model that is but I spent significant time in Woo's room last year at CAF and both sound and build quality were great.
Can't seem to find much info on Little Dot.
ajzepp
Re: headphone amps
« Reply #8 on: 7 Aug 2013, 12:17 am »
I love my Little Dot amp...I used it exclusively for my Grado phones. Incredible value.
