Sold: Cary PH-302 MKII Tubed Phono Preamplifier - Mint Condition
0 Members and 1 Guest are viewing this topic. Read 3083 times.
dminches
I am selling my Cary PH-302 MKII phono preamplifier. I am the original owner. The unit is in mint condition.
This is an excellent, neutral sounding phono pre. It handles both moving coil and moving magnet cartridges.
From Cary's web site: "Moving coil and moving magnet phono preamplifier with 5AR4 vacuum tube voltage regulation. Shielded R-Core power transformer, separate step up transformers for MC cartridges, separate inputs for MC or MM cartridges, MM optimized for 47 k ohm load, MC externally adjustable from 10Ω to 47kΩ loads. Fully regulated power supply section, dual triode vacuum tube buffer and gain stages. High gain design with 60 dB overall gain in the MC section. ZERO feedback design."
This unit is the black faceplate version.
Along with the pre amp I will send the original 5 stock tubes (4 6SL7s and 1 5AR4) which are unused. The unit is great if you like to tube roll since there are many options for 6SL7s/ECC35s.
I will cover all shipping (CONUS only) and paypal fees.
Asking price $old.
« Last Edit: 16 Aug 2013, 07:14 pm by dminches »
dminches
Price reduced
