0 Members and 1 Guest are viewing this topic. Read 3321 times.
Personally, I don't think this is the answer for you if your worried about getting water into your basement from a downpour. It really sound like you need to get a down spout adaptor and connect a good length of hose to it to get the water away from your house. Or, put in some 2" PVC pipe and put it under the sod, hopefully to a lower area, away from the house. Wayner
I don't think Wayner meant a garden hose. They're too small to use to capture roof runoff directly.
And that success was collecting rain water.....
You got it! Plus keeping high need plants watered (hops). Wayner, everyone knows you don't like or accept anything you don't do. So why not stick to glueing sticks to phono carts.
Sure the rain barrels can make you feel good, (your saving the earth), but in reality, does nothing but make a breading ground for bug based diseases.
