electronic crossover for LS-6
0 Members and 1 Guest are viewing this topic. Read 1350 times.
rak313
« on: 29 Jul 2013, 10:38 pm »
Danny,
I am new to AC, although I have lurked for a few years now.
I have a pair of ls-6s (from AV123 received new 8/2008) and am thinking of adding a LS-C or N3s for a center (or even the Carnegie Acoustic CSC-1 - if you still have them) .
My receiver is in need of upgrading, and I am thinking of getting a professional amp like QSC or Beheringer or other.  Some of these amps have built in digital  crossovers for bi-amping.  They take the analog amplifier input, A/D --> digital lowpass/highpass --> D/A --> output to a pair of amps.  While it does introduce an additional A/D-D/A step, it eliminates the electronic crossover and any issues with quality of inductors/capacitors/resistors.
The setup options on these electronic crossovers are pretty limited, eg. center freq and slope.
I so I have 2 questions for you:
1) do you still have and of the CSC-1 centers? (even though the LS-C is pretty - it still has size issues with my wife)
2) What do you think of modifying the  LS-6 for electronic crossover? (or other of your speaker designs).
Rick
Danny Richie
Re: electronic crossover for LS-6
« Reply #1 on: 31 Jul 2013, 06:50 pm »
Carnegie has plenty of the CSC-1's left. So no issue there.
I wouldn't use any of those digital crossovers with the LS-6 though. That would be a huge backward step. There is a reason that those units are so cheap. The quality of the parts involved are about the same as what you get in a CD player that you buy from Walmart for $49. Yes, the quality of the D/A conversion is that bad.
Stick with the passive crossover and put your money into a good DAC.
rak313
« Reply #2 on: 31 Jul 2013, 08:43 pm »
Thanks for the response.
What I had in mind was a QSC DCA 1622 or DCA 2422
http://www.qscaudio.com/products/amps/dca/dca2/dca2.htm
with the X3 digital crossover plug in
http://media.qscaudio.com/pdfs/manuals/Cinema_Accessories_revB.pdf  This combination is aimed at professional cinemas.
While I can't comment on the quality of the A/D D/A in the X3, I would think the A/D D/A of the QSC PLD line is good.  This product line is intended for use for live performances in large theaters, and includes programmable crossovers, and equalization.
http://qsc.com/products/Power%20Amplifiers/PLD%20Series/
Danny Richie
« Reply #3 on: 1 Aug 2013, 01:32 am »
That gear is designed primarily for the pro market.  A digital crossover like that is not something you'd want to use with a high end speaker like the LS-6. Stick with the passive crossover and get a good quality DAC and the end result will be MUCH better.
Danny Richie
« Reply #4 on: 1 Aug 2013, 02:52 pm »
And rak313,
Welcome to AC.
Feel free to post here anytime.
