0 Members and 1 Guest are viewing this topic. Read 11050 times.
Oddly, I had the HiFiMan HE-400's on my short list based on this link, but for some reason left them off. http://www.head-fi.org/t/634201/battle-of-the-flagships-58-headphones-compared-update-audeze-lcd-2-revision-2-6-4-13#user_HE400 That HiFiMan speaker adapter with a speaker selector is something I will look into wrt the HE-5LEs, etc.. Seems like my little 32w amp has been used successfully as a headphone amp.
(Russtafarian, your avatar made me want to get 'The Scream' to use on another BB- and I found this! Thanks!)
People also use speaker adapters for the HE-500, which I own. I am using a Schiit Lyr with my 500's, and am very happy with the setup. I bought my pair on sale, but they would still use most of your budget. But, if this is going to be your main mode of listening, I would spend as much as I could on the cans now knowing you will need to come up with more money for an amp (unless you just use a speaker adapter).Randy
Is your screamer using sealed or open-air cans? I'm guessing he's singing along to Wish You Were Here.
I also use a TubeDac-11's Line Out the way you're planning as my headphone source into a Project Sunrise II amp driving AKG Q701 headphones (I see the K701's are on your short list already). I'm extremely happy with this combo and have the same SQ preferences and priorities you've listed.The term "project" is a bit of a misnomer in the amp name because you can buy it fully built and warrantied from the company in the US that designed this amp (that's what I did). The output impedance is easily configured for different headphones (I like the 5 Ohm setting for the Q701's) and you can use most all 6V or 12V tubes with it so you have lots of flexibility if you need it.
gGiven the budget, you are not going to do better than the amp you have with an adapter. I use an HE-6 with an adapter but have heard the he-400 with an adapter on a good speaker amp and they sounded pretty good.
