BP25 DA vs SP 1.7
0 Members and 1 Guest are viewing this topic. Read 1599 times.
naim
BP25 DA vs SP 1.7
« on: 23 Jul 2004, 10:16 am »
When used as a pre-amp in a stereo set-up, is the SP 1.7 then as good as or better than the BP25 DA?
Regards
naim
jethro
BP25 DA vs SP 1.7
« Reply #1 on: 23 Jul 2004, 01:12 pm »
If you are using an analog connection, then the SP 1.7 (in bypass mode) is exactly the same as the BP25DA. If you are using a digital connection, then the two are different. The BP-25DA contains jitter correction hardware that the SP-1.7 does not include. I believe that the same DACs are used in both units. I haven't heard the BP-25DA, but I would assume that it is better in digital mode for listening to music than the Sp-1.7 in digital mode.  There are a number of threads on this topic that might be of interest.
