Life span of caps in 4B ST
0 Members and 1 Guest are viewing this topic. Read 3659 times.
Shadorne
« on: 28 Jul 2013, 06:49 pm »
Just wondering what is the typical expected lifespan before it becomes advisable to re-cap? Warranty runs 20 years but surely with all that heat coming off these amps, the electrolytic ones in the audio path (not so worried about the power supply as these amps are so overbuilt that some degradation there probably won't matter) will slowly degrade. Just wondering when does this start to become something that is worth checking?
rmurray
Re: Life span of caps in 4B ST
« Reply #1 on: 29 Jul 2013, 12:51 am »
 I have a 4bst that's 12 years old. I would like to know that too : :scratch:
Shadorne
« Reply #2 on: 29 Jul 2013, 02:22 am »
Exactly the reason I ask. I have a 99 and a '00 "pro" model making them 13 and 12 years old respectively. These amps are beautifully built but I don't expect that Bryston will have solved the inherent problem that all electrolytic caps do age and dry out (even when not used) and they also tend to age more quickly under stress from high levels of heat. Perhaps the question would be better asked in overall terms of hours and age and when is it considered advisable to have them re-serviced?
(FWIW I have personal experience re-capping a 19 year old but good amplifier (not Bryston) and it definitely made a difference - highs were less rolled off after the caps were replaced - probably a coupling capacitor was getting long in the tooth)
spinner
« Reply #3 on: 29 Jul 2013, 11:01 am »
Perhaps there are better caps available as well. :)
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 29 Jul 2013, 11:20 am »
Hi folks
I will ask engineering. I know it is based on operating temperatures vs lifespan expectation.
James
Shadorne
« Reply #5 on: 29 Jul 2013, 01:47 pm »
Hi folks
James
Thanks James.
I read somewhere that Bryston have produced something of the order of 30,000 4B-ST so my guess is your engineering will have a "rule of thumb". For others reading this I want to be clear that electrolytic capacitors are used in nearly all analog audio applications so lifespan of these items will affect nearly all amplifiers and this is not a reflection on Bryston build quality, which everyone knows is second to none.
Stilgoe
« Reply #6 on: 19 Nov 2013, 09:05 pm »
Hi folks
James
Any answers on this? Are caps covered in the 20 warranty then?
« Reply #7 on: 19 Nov 2013, 09:15 pm »
Engineering tells me the caps are rated given their temperatures for 50 year life span.
james
spinner
« Reply #8 on: 19 Nov 2013, 09:32 pm »
  James if one changes them would newer ones be somewhat finer or would they be identical to originals? :scratch:
« Reply #9 on: 19 Nov 2013, 10:35 pm »
Identical if all is working as it should.
james
rmurray
« Reply #10 on: 20 Nov 2013, 01:57 am »
 Now that says a lot about military spec Brytson build quality. Proud to own a 4Bst : :weights: :dance:
Elizabeth
« Reply #11 on: 20 Nov 2013, 12:21 pm »
james
Good to know. And what is typical of Bryston IMO. Fifty years.. OK!
alexone
« Reply #12 on: 20 Nov 2013, 10:02 pm »
...49 years would be ok, too :wink:
al.
