Parasound HCA 1500-A Trigger Question / Use for Larger Sub
0 Members and 1 Guest are viewing this topic. Read 1973 times.
guest1121
  • Guest
I know this amp has a trigger input for remote turn-on, but can anyone tell me if it has a trigger output for passing the trigger signal on to another amp?  From pictures, it is hard to tell.
I'm thinking about using this amp to power a VMPS Larger Sub.
lkosova
    • http://www.AutomatedHomeandBusiness.com
« Reply #1 on: 23 Jul 2004, 02:35 am »
You can trigger the amps to one another if that is what you are asking. When turning one on it can turn the others on.
Larry
guest1121
  • Guest
« Reply #2 on: 23 Jul 2004, 08:18 pm »
Yes that was what I was asking.  In essence I want to "daisy chain" the amp to other amps but in order to do that, I have to be able to pass the signal from the Parasound amp to other amps.
Thanks for the response Larry.
lkosova
« Reply #3 on: 23 Jul 2004, 08:57 pm »
I have three Parsound 1000a's and it works that way. I would call the tech support to make sure it will do what you want it to . They are very nice people.
Larry
guest1121
  • Guest
« Reply #4 on: 23 Jul 2004, 10:21 pm »
I just called Parasound at your suggestion, Larry, and was told all they're amps have that ability.  Very cool - think I'll get one.
lkosova
« Reply #5 on: 24 Jul 2004, 01:52 am »
Good.
I know that they did just wanted to make sure you knew that. I am using the Cary amps now.
If you need help getting the amps at a good price let me know. My distributor has them.
Larry
