Problem with BAT preamp
0 Members and 1 Guest are viewing this topic. Read 1392 times.
DrRasta
« on: 23 Jul 2004, 01:44 am »
Anyone else using a Balanced Audio Tech preamp with the Odysseys?  I've had problems with my vk-5se and the Stratos monos.  I sent the preamp into BAT and they said everything is fine.  My problem is sound cutting out when using the stratos.
They feel there's a ground problem, perhaps the pinout on the connectors is different on the Stratos.  Anyone have any ideas?
klaus@odyssey
    • http://www.odysseyaudio.com
« Reply #1 on: 23 Jul 2004, 02:00 am »
Stratos :  Pin 1 is ground,  and pin 2 is hot.  Check with BAT, that could be the problem.
DrRasta
BAT confirms
« Reply #2 on: 5 Aug 2004, 02:14 pm »
BAT found an intermittent problem with a solder joint.  The pinout is the same as Klaus describes....
Gil
