Audio/Video Gear and Systems
Tube-o-phile Circle
JakeJ
CantSeePics
CantSeePics
0 Members and 1 Guest are viewing this topic. Read 1104 times.
rlblack
Newbie
CantSeePics
27 Jul 2013, 02:19 am »
Please help! why cant I see the photos in the thread Dynaco FM-3 rebuild - "A Double Dose of Fine Tuning!"
thanks for any help. I just bought a fm-3 with all original tubes but a pretty bad home build. I suspect I will need to redo the whole thing. anyone with insight I would love some direction. don't know a lot, but I can solder. built a couple of kits.
thanks
JerryM
Where's The Bar?
Re: CantSeePics
27 Jul 2013, 03:33 am »
It appears the pictures are just *gone*...
In any case, check out
this post
made by Frank Van Alstine. It's a bit dated, but you should reach out to him.
Best of luck, and welcome to AudioCircle!
Jerry
JohnR
Administrator
testingtesting
Re: CantSeePics
Reply #2 on:
27 Jul 2013, 01:41 pm »
Unfortunately, Bill Thomas had hosted those images on an external site. Might I suggest to all that images essential to a thread be loaded into your audiocircle gallery, as they will then at least last as long as the thread does.
Tube-o-phile Circle
JakeJ
CantSeePics
