3.3 crossover -3db points
0 Members and 1 Guest are viewing this topic. Read 1305 times.
Mike D
« on: 27 Jul 2013, 01:36 am »
Does anyone know the -3db points and polarity for the 3.3?
Is there any difference between the IIIA and 3.3 panels?
Thanks again
neolith
Re: 3.3 crossover -3db points
« Reply #2 on: 26 Aug 2013, 05:31 pm »
The big difference in the IIIa and 3.3 was  a change in the ribbon. The ribbon on the IIIa is a tad shorter (the housing is 60" while the 3.3 is 60.5") and wider thus having a lower impedance. This required a 1 ohm resistor to bring the impedance up to 3.3 ohms. The ribbon in 3.3 is the same that is used in 3.7 and 20.7 and all the models in between. I believe the mid-bass panel is the same.
