Feet for a Billy Bags Rack?
0 Members and 1 Guest are viewing this topic. Read 1000 times.
ereplogle
« on: 26 Jul 2013, 09:17 pm »
I recently purchased a Billy Bags rack that was in good shape (model #4803, I think). However, it is missing the feet. I am wondering if anyone here might know of a good alternative to the spiked feet that originally came with the rack. The rack will be setup on hardwood floors.
The guy I bought it from suggested looking for furniture glides. The bottom of the feet each have an insert for 1/4" x 20 thread.
Any ideas? Or should I get the threaded feet and then what do I use to protect the hardwood floor?
Photon46
Re: Feet for a Billy Bags Rack?
« Reply #1 on: 28 Jul 2013, 11:09 pm »
I ordered my double wide BBags rack with the factory glide feet. Maybe a spike would possibly sound better, but the practicality of being able to slide the rack when I need to move it works for me. As far as I know, you can still order whatever style of foot you want from the factory. They used to be listed on their website, but the new website kinda s*cks compared to the old one IMO. If you decide to go with spikes, there are many choices of floor protectors to use under them. Herbie's sells some good ones.
http://herbiesaudiolab.net/base.htm
