3 and 4 sets of 8 ohm speaker connections
0 Members and 1 Guest are viewing this topic. Read 2073 times.
chalmersiv
« on: 19 Jul 2013, 10:54 pm »
How to wire 3 sets of 8 ohm  advent speakers to a amplifier ??????
Bob in St. Louis
Re: 3 and 4 sets of 8 ohm speaker connections
« Reply #1 on: 20 Jul 2013, 05:10 pm »
That isn't enough information to give you a solid answer, but check out this page:
http://www.bcae1.com/spkrmlti.htm
It's tailored for cars, but the principles of "Ohm's Law" doesn't change.
Good luck, and rock on.  :thumb:
KenSeger
  • Heavy and noisy, but beautiful
    • Ken's Plain Jane Website
« Reply #2 on: 20 Jul 2013, 09:32 pm »
What amplifier are you using?
Series would present a nice safe boring 24 ohm impedance.  Parallel would present a white knuckle 2.667 ohm impedance.  This assumes the speaker in question is truly 8 ohms of impedance at all frequencies. :shake:
The only speakers that I know of that do NOT have peaks and dips in in their total impedance as a function of frequency are Magnepans.
If your amp tends to leak smoke on a load of less than 4 ohms of impedance, parallel is out.
If your amp tends to leak smoke on a load of less than 2 ohms of impedance and *IF* the Advents have a dip of less than 6 ohm, parallel is still out.
You can wire three speakers and one 8 ohm load resistor in series-parallel or parallel-series for an 8 ohm load, but 25% of your power will go up as heat.  Which is better than having your amp go up in flames, or just going into shut off mode if the safety circuits work properly.
Ken
chalmersiv
« Reply #3 on: 24 Jul 2013, 10:50 am »
thanks.....the 8 ohm resistor looks to be the answer until I find the 4th set of speakers ....
bpape
    • Sensible Sound Solutions
« Reply #4 on: 24 Jul 2013, 03:57 pm »
Or, you can wire 2 pair in series, then parallel those to the 3rd pair.  If 8 ohm starting point you end up with 12 ohms.
Bryan
KenSeger
« Reply #5 on: 24 Jul 2013, 09:08 pm »
Bryan
Uh? you lost me.  Two 8 ohms in series = 16 ohms.  16 ohms in parallel with 8 ohms = 5.333 ohms.
Ken
P.S. in the 2 series paralleled with one, when each of the two in series get 1 watt each, the single unit in parallel would get 4 watts.  If this is for 'stacked' advents, I'm not sure, but I think the results would be weird???
Donald
« Reply #6 on: 24 Jul 2013, 09:21 pm »
Not totally purist approach, but another option would be to buy a speaker selector switch with impedance protection and volume controls in the event you wish to have different volumes in different speaker locations.
mjmsound
« Reply #7 on: 25 Jul 2013, 01:42 pm »
Take the guess work out of it and play it safe, buy some amplifiers!  :|
daves
« Reply #8 on: 25 Jul 2013, 06:12 pm »
Or throw away some speakers.  :icon_lol:
