SOLD - AMR (Abbingdon Music Research) AM-77.1 Integrated or standalone amp
0 Members and 1 Guest are viewing this topic. Read 1529 times.
tdangelo
Retail $10,999.00 - will sell for $4799.00 + shipping
Dual mono integrated amp - at the heart is a no compromise combination of zero negative feedback, pure Class A valve stages(2x 5687) in the pre-amplification section coupled in the power amplification section, with bipolar output devices in AMR’s proprietary “Class X: Jikoda” circuit. The amp was designed to be a solid state expression of an SET amp. The sound is absolutely wonderful - lush, resolved and powerful! The amp is able to be operated as a stereo integrated or stereo amp controlled by an external preamp or mono if you already own one. Please check out the manual and specs at AMR. I bought the amp about a year ago from the US distributor - he and Vince from AMR upgraded it to the 77.1 version in late summer of 2011. When it was being upgraded the Speakon connectors and the USB IPOD charging port were disabled(better sound I was told) but they can easily be reconnected if necessary. The physical appearance is very good - no scratches on the aluminum casing or display panel that I can see - just one small item - a couple of the speaker binding posts have a loose plastic cover - it pulls off and you can tighten the post easily with your fingers - this is just the cover not a loose internal post - its not a problem if you use banana connectors. I have the original aluminum flight case and the external box - the nice manual and solid aluminum remote with motion sense for lighting. It's been about a year and I have the change bug ;) The amp is very heavy at 90lb and 125lb in the flight case so shipping will be a bit expensive but safe due to the flight case. Paypal is acceptable with an additional 3% fee - buyer is to pay all shipping/insurance costs - local pickup is welcome. Oh, the amp will automatically adjust to different voltages so that it can be used outside the USA. This is a very high quality amp with top notch components and engineering - be sure to read the reviews if interested.
« Last Edit: 15 Aug 2013, 07:46 pm by tdangelo »
tdangelo
