New Ultrasonic Vinyl Cleaner
0 Members and 1 Guest are viewing this topic. Read 5176 times.
BruceSB
« on: 16 Jul 2013, 05:01 am »
Here is a new ultrasonic vinyl cleaner.
Key differences to the other one are:
* uses distilled water only;
* no brushes or drying pads.
Here is the link: http://klaudio.com/
Looks really interesting.
Bruce
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
Re: New Ultrasonic Vinyl Cleaner
« Reply #1 on: 16 Jul 2013, 05:33 am »
So does a stack of 40 Benjamins ...
BruceSB
« Reply #2 on: 16 Jul 2013, 07:29 am »
I'm sorry.
I live on the other side of the planet.
I have absolutely no idea what a Benjamin is!!!
Bruce
hawaii.guy
« Reply #3 on: 16 Jul 2013, 08:07 am »
Benjamin
JohnR
« Reply #4 on: 16 Jul 2013, 08:21 am »
Hi Bruce, I think he means that it's big bikkies :D
BruceSB
« Reply #5 on: 16 Jul 2013, 08:30 am »
Thanks John.
Yes, he is right on that one!
toocool4
« Reply #6 on: 16 Jul 2013, 02:36 pm »
Wow i am liking the look of this one, it has a lower running cost compared to the Audio Desk Systeme.
I was looking into getting the Audio Desk Systeme as i currently have the Loricraft PRC3.
If this one does what they say, it look like a better option to the Audio Desk Systeme.
vinyl_guy
« Reply #7 on: 16 Jul 2013, 03:00 pm »
I have the Audio Desk Systeme and it works great. I've cleaned more than 50 records in two weeks.
Laura
toocool4
« Reply #8 on: 16 Jul 2013, 03:08 pm »
Yes the Audio Desk Systeme was the one i was interested in to replace my Loricraft, but the running cost of the Audio Desk did put me off a bit. I think if this KL Audio ones does what is claims, it looks like a better option.
vinyl_guy
« Reply #9 on: 16 Jul 2013, 03:12 pm »
It does look like a nice unit and I like the idea of not having a lot of moving parts and brushes to replace. I kept my Loricraft to use to pre-clean any really dirty records. I wonder if they are going to be at CAF or RMAF. I would like to see one in operation.
xsb7244
« Reply #10 on: 16 Jul 2013, 06:03 pm »
xsb7244
« Reply #11 on: 16 Jul 2013, 06:12 pm »
See diyaudio forum.  Read the thread My version of an Ultrasonic Record Cleaner.  This is the most detailed information anywhere on the subject..  Building or buying an ultrasonic cleaner is more complicated than you think.  That is why it cost so much unless you build it yourself.
toocool4
« Reply #12 on: 16 Jul 2013, 08:59 pm »
The price is not what bothers me, but the running cost of the Audio Desk Systeme.
gundam91
« Reply #13 on: 21 Jul 2013, 07:01 am »
The point of most cleaning fluid is to get rid of the mold release compound which was applied during the pressing of the LP, in addition to the usual dirt, mold, mildew, etc. Are they suggesting that their version of the ultrasonic vibration alone will get rid of this as well? I am a little skeptical. I believe that is the reason why Audio Desk's machine still require using this type of solution.
BruceSB
« Reply #14 on: 4 Sep 2013, 10:18 pm »
orthobiz
« Reply #15 on: 5 Sep 2013, 01:58 am »
How could the price of both just "happen" to be 4000 dollars?
Paul
BruceSB
« Reply #16 on: 5 Sep 2013, 03:33 am »
Yeah!
Real coincidence.
He he.
toocool4
« Reply #17 on: 16 Oct 2013, 12:23 pm »
If you are in Europe and buy it in Euros it’s €2299 or $3118.
The KLAudio looks like a cheaper option since the running cost is lower.
http://www.technologyfactory.eu/index.php?item=audio-desk-systeme-vinyl-cleaner-standard&action=article&group_id=10000487&aid=837&lang=EN
