Celestion 15" pro sound driver from Parts Express
0 Members and 1 Guest are viewing this topic. Read 2183 times.
chrislittle
Hi, I just bought four Celestion drivers from Parts express for $49 apiece and I want to use them in an 18"x48" OB with a Dayton 8" full range point scource. Acording to the Martin King site I'm withgin the 6 to 10 db range between the fullrange and the woofers in paralell. I don't think I have the software to run the programs I have found recomended on this site to predict the dipole peak, so I'm just using a formula I found on the site 1126x12/2xRadius inches. For Radius inches I'm using 1/2 width + 1/2 width. I know there are other issues like the floor and the vertical measurement, but can this formula get me into the ballpark where I can start the LP an octave below, and the HP an octave above, and then manipulate the component values by ear to find a balance?
I have also seen a really interesting OB where they used 8 layers of 3/4" plywood to make a 6" think baffle which increases the width measurement by 12 inches without actually changing the width. Does anybody have a take on either of these ideas?
Thanks, Chris
mcgsxr
Re: Celestion 15" pro sound driver from Parts Express
« Reply #1 on: 11 Jul 2013, 11:55 am »
Welcome to the site Chris, and sounds like you have found something fun to experiment with.
From my experience, having only ever tuned by ear, I am sure you can get a feel for the experience by ear, and then decide if you want/need to explore taking the next step, or if it is just not for you.
For my experimental baffles, I used piano hinge to attach wings of various widths.  Easier than making the baffle thicker, though I suspect I know why they tried that too.
I found running active much easier than exploring using passive components.  I used a small tube amp for my main drivers, and a subwoofer plate amp for the subs.  I eventually bought a small active Xover to try to optimize the experience.
I also found that using the subs in the main baffle muddied the mids, regardless of Xover frequency, but I understand the appeal of 2 baffles vs 3 or 4!
Good luck with it, let us know how you make out.
Alan
« Reply #2 on: 11 Jul 2013, 05:42 pm »
Cool project! I'm doing something similar.
As Mark mentioned, perhaps easiest to run the Dayton without crossover and a plate amp for the bass.
I'm using minidsp, an excellent solution. Here's a guide http://www.hifizine.com/issues/minidsp-tutorials/
If you really want to do a passive crossover, this should put you on the right path
http://www.diyaudio.com/forums/multi-way/189847-introduction-designing-crossovers-without-measurement.html
Have fun with it!
chrislittle
« Reply #3 on: 11 Jul 2013, 09:03 pm »
Thanks for the comments!
I'l post when I build.
I'm pretty sure I want to do everything passive though. I have had bi-amp systems before but I went through a simplification during my last couple of speakers and I don't really want to go back. Had I realized that I would get into open baffle speakers while I had my bi-amp system I might have stayed with it, but now that I have simplified I want to stay that way.
Like mentioned I have also read in other places too that the Daytons sound pretty good full range. So I really only need to focus on a crossover point for the woofers.
Is there a way though that I can predict what the natural roll off of the daytons is in my particular baffle?
Is it right below the dipole peak which I figure is around 440, or is it closer to the driver Fs 37? Based on what I have read it seems like it would be between 100 and 440.
