***SOLD*** Chord QuteHD (DSD) & MCRU Power supply
0 Members and 1 Guest are viewing this topic. Read 3075 times.
Ern Dog
« on: 10 Jul 2013, 04:58 pm »
I bought the QuteHD new about 3 months ago from Acoustic Sounds.  It is in Excellent condition and is now fully broken in.  It comes with wall wart power plug, install cd, USB cable and original packing.  No manual was included, but you can easily download one online.  Retails for $1800.  Here is more info, specs and reviews: http://www.chordelectronics.co.uk/products-info.asp?id=78
The MCRU is an external linear power supply unit built specifically for the QuteHD.  It replaces the stock wall wart and significantly improves the sound.  I bought it 2 months ago direct from MCRU in the UK and I paid $340 shipped.  It is in Excellent condition.  Here is the manufacture link for more info, specs and reviews: http://www.mains-cables-r-us.co.uk/power-supplies/514-chord-qutehd-linear-power-supply.html
I'm selling both items as a package for SOLD shipped within USA.  Paypal (personal gift) or money order.
Here is my Audiogon feedback: http://app.audiogon.com/users/erndog/feedbacks
PM me if you have any questions or we could talk on the phone too.
Ernie
« Last Edit: 22 Jul 2013, 03:45 am by Ern Dog »
Ern Dog
Re: FS: Chord QuteHD (DSD) & MCRU Power supply
« Reply #1 on: 13 Jul 2013, 11:19 pm »
Will be posting this on Audiogon soon....
Ern Dog
« Reply #2 on: 19 Jul 2013, 02:47 pm »
Although the back of the MCRU power supply says "240v AC input" it is configured for USA operation of 110v.  Each one of the MCRU units are hand made to order and so I ordered mine to work with 110v.
The double box design is very interesting too.  Here is the explanation of why it was designed with two separate enclosures:
"When thinking of regulation, it’s worth remembering the Roman god Janus. Who was the god of gateways, and was a two faced god looking in both directions. Likewise a good voltage regulator is required to look in both directions at once. From one direction you have the mains supply, with the ever increasing noise, distortion and random variation that exists on our household mains supply. In the other direction you have the device you are supplying power to. The load will be asking constantly varying current, and the job of the regulator will be to ignore the varying load and to supply a rock steady voltage that ignores the changing load.
To ask a single regulator to perform both tasks means that it can not do either as well as it could. We don’t ask our regulators to be two faced, we split the two functions into two separate regulators and put them both where they can do the best job.
The first regulator is close to the mains supply, its job is to take the incoming mains and convert it into a low(ish) noise DC supply, and to isolate the mess that is our household power lines from what follows. In most power supplies on the market, the output of the first stage would be directly connected to the load device, and that would certainly be an improvement over the supplies that most manufactures provide. But we can do better by adding the other face of Janus to the system.
The second regulator is supplied with a clean low noise supply, and its job is to handle the changing demands of the load. To do that, it needs to be as close to the load as possible. So we remove the second regulator from the main box, and place it close to the load, both electrically and physically, that removes it from the noise and interference of the mains supply, and allows it to spend its time looking towards the load. Typical commercial voltage regulator chips are general purpose devices, but are not quiet enough for the task on hand, so the second regulator uses a bespoke regulator based on a low noise multi stage filtered voltage reference, a low noise error amplifier and a high current low resistance mosfet. To allow it to handle the changing load it also needs to supply current on demand, so all the remaining space in the second regulator is filled with low impedance capacitors to act as a local energy source.
Using the two stages of regulator, we achieve a noise floor equal or better than most battery supplies, and a effective source resistance of the order of 0.02 ohm (and the short cable run to the load avoids increasing this valve by adding copper where its not needed, and the use of a discrete regulator design allows that tiny value to be maintained way above frequency any audio device operates at."
Ern Dog
Re: ***SOLD*** Chord QuteHD (DSD) & MCRU Power supply
« Reply #3 on: 22 Jul 2013, 03:45 am »
SOLD
