Best Media Player for Windows 8????
0 Members and 1 Guest are viewing this topic. Read 4948 times.
Sonny
« on: 8 Jul 2013, 08:28 pm »
So, what is the preferred music player for windows 8?
Jriver?
anything else?
Want to stay under $100.
Phil A
Re: Best Media Player for Windows 8????
« Reply #1 on: 8 Jul 2013, 09:28 pm »
I'm using JRiver on my Windows 8 music server but also have Foobar (which is free).  JRiver is more user friendly to a non-computer geek and I have not as yet figured how to do DSD files with Foobar (but can do hi-rez PCM from them) and it sounds good.  With JRiver and a tablet or smartphone you can also get the jRemote App for $10 and use it as a selection device.
Sonny
« Reply #2 on: 8 Jul 2013, 10:28 pm »
FOOBAR, is good and free, as you said and as I've heard.  Can it play from a music folder or do I have to select songs individually?
chip
« Reply #3 on: 8 Jul 2013, 11:03 pm »
What type of files do you want to playback?
What are you hooking this device up to?
Sonny
« Reply #4 on: 8 Jul 2013, 11:18 pm »
Well, it's going to be on an ASUS laptop, which will connect to a 3TB External HD...
Will be playing FLAC, Lossless, etc.  NO DSD.
HAL
« Reply #5 on: 9 Jul 2013, 12:06 am »
Foobar2000 will play an entire music folder or individual files.  Usually I setup the recordings by a folder with full CD's files in them with the folder name of the CD.  If you then click on the CD name and send it to the playlist it will play the entire CD.
For PhilA, to use Foobar2000 for Native DSD files, you need to change the output components.  There was supposed to be an upgrade awhile back to the DSD output components to make them work correctly.
Sonny
« Reply #6 on: 9 Jul 2013, 12:10 am »
Thanks HAL!
Phil A
« Reply #7 on: 9 Jul 2013, 01:07 am »
Rich - have not gotten to it yet.  I spent most of the long weekend sitting down in front of the PC - bought dBpoweramp and began ripping my CDs (I had pieces previously done in WMA but decided to try to get as many ripped as I can as I still have classical DSD files to extract and DVD-As to rip) and that's what I'm doing right now (so hopefully less to do after the move).
I read that this what I need to do:
Go to File > Preferences > Output and Select foo_dsd_asio
Go to Tools >SACD> Asio Driver Mode and select 'DSD'
Click 'Apply' and 'OK' and 'OK'
If I don't get to it on my many things to do, we can do it in September.  Been breaking in the WyWires USB cable too that I now have on the MS-2  Only about halfway through the CDs.  Making back-ups of the back-ups after this effort.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #8 on: 9 Jul 2013, 06:12 pm »
Once you know how to use Foobar, its a powerful music player with lots of features. Even the GUI can be fully customized.
Sonny
« Reply #9 on: 9 Jul 2013, 06:15 pm »
I guess I need to read the manual or go on "help" function?
Also, Figured out the Library thing, how do you get it to display album art, etc?
Hipper
« Reply #10 on: 9 Jul 2013, 07:07 pm »
I use Jriver MC 18 on Windows 8. It works fine so far.
It can also be used with a touch screen in its 'Theatre View' although I prefer the normal layout and use a touchpad to navigate.
Phil A
« Reply #11 on: 9 Jul 2013, 07:45 pm »
Sonny - A Member here (Fork) also is a dealer for selected items (I've gotten some fuses and tubes) and has a short guide.  I have not used anything from it - http://www.jaguaraudiodesign.com/blog/?s=foobar
Sonny
« Reply #12 on: 9 Jul 2013, 08:10 pm »
Thanks Phil.
How do I go about getting FOOBAR to show the album art?
chip
« Reply #13 on: 9 Jul 2013, 08:15 pm »
Foobar skins - http://customize.org/foobar/skins
I just setup the Neutron one on my work PC. Still trying to figure out a few things but I do like the layout.
Neutron Skin - http://customize.org/foobar/skins/88791
chip
