0 Members and 1 Guest are viewing this topic. Read 13570 times.
I do not understand. That completely messes up my possible experimentation this weekend. It also nixes the neat package idea of using a small PC with built in optical drive or Mini with an external optical drive duct taped to it.
You need to install the monkey audio encoder,http://www.foobar2000.org/components/view/foo_input_monkeyFirst download the component then open foobar and :Step 1: Open the foobar2000 preferences dialog (click File | Preferences or key CTRL+P).Step 2: Go to the Components page.Step 3: Click the "Install..." button and select the component archive ( it is where you saved the file when yiou downloaded it) or simply drag it to the list.Step 4: Press "OK", you will be prompted to restart foobar2000 in order to load the newly installed component.That is not one of the more common audio formats, did jriver do that on its own?
Wow Don - you're one unlucky dude. Never even hear of cda or ape file formats......How about this for simplicity & reliability: 1. Turn on Mac (if you're not connecting to internet over wi-fi, connect ethernet cable to router)2. Start Itunes.3. Got to "Itunes / Preferences / General / Import Settings" and choose Apple Lossless (or WAV if you're really paranoid). I have also have my choice as "when you insert a CD : import cd". You can make other choices such as : ask to import cd". Lastly, if for some reason you don't like or want to change the default storage location, go to the "advanced" tab in preferences & tell it where you want to store (e.g. an external hard drive).4. If you haven't already done so, connect the USB DVD / CD drive.5. Insert CD and let it rip the file to your library & automatically get the artwork, etc.6. Listen to the first track if you like, have a drink, and enjoy. After a few minutes, a ding will sound, remove disk, add another.Think folks complain to much about the ripping process. Is it really that arduous folks to put a new disk in every couple of minutes? Something you can do will you surf the web, listen to music, whatever. Or if thats too much work, there are commercial ripping services that you can send your collection to and they will rip it and put it on a hard drive in your preferred format.Best of luck Don!
At the risk of being obnoxious - at which I'll likely fail - in your place I'd be avoiding these wonky & irritating programs - and Jriver is probably one of the more polished - and just embrace the ubiquitous and easy Itunes. Life's too short.......W/ Mac's you click the Apple icon at the top left corner of your screen, choose "about this Mac", then the "more info" button.........
jarcher, You are right. Life is too short. Too short to listen to less than the best I can manage. I want the best I can get and I do not want to be wedded for better or worse till death do us part to anything proprietary. I want my library to be portable as in .wav or FLAC.Sadly I think there is a great conspiracy afoot---let's get Don. Remember, my Mini is used. My friend loaded it with so much social media (plus iTunes, imovie, iPhoto, icrap, ucrap we all crap) crap I can't believe it. If I decide to purchase it I will do massive cleaning if I can find the program that corresponds to a PC's add/remove programs. In the meantime I have failed to find the alleged Apple logo. I learned left from right in kiddygarden and know up from down. I even know what an apple looks like. But alas, there is no Apple logo on my Mini's screen.
OK, What am I doing wrong? I downloaded JRiver Media Center and could not figure out how to rip into different formats (.wav or FLAC).
With jriver for windows it's at Tools/Options/Encoding.
